Toinen mersu...Kesälook kuva
Tu0mas
Viesti Kirjoittaja Tu0mas »
Toinen mese tuli hankittua ja ajattelin samalla liittyä tämän sivuston jäseneksi. Eli kyseessä on w124 300ce-24. Olen ollut tyytyväinen autoon, vaikka pientä laittamistakin löytyy. Yritän saada kuvia myös lähiaikoina.
Paint
481 bornite (blackberry) metallic (с 01.01.1990 по 31.12.1996)
Options
240 outside temperature indicator (с 01.03.1982)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
281 trunk set, (280 SL)
steering wheel (390 mm) with sports design (с 01.03.1989)
412 electric sliding roof with tilting device (с 01.07.1983)
420 automatic transmission, floor shift (с 01.01.1963)
430 headrests in the rear (с 01.01.1977)
442 airbag in steering wheel (с 01.02.1980 по 31.10.1993)
471 acceleration skid control (ASR) (с 01.07.1984)
511 Becker radio Grand Prix cassette electronic stereo, Kurier, LW/MW/USW (с 01.11.1982 по 30.11.1990)
Becker radio Mexico cassette full stereo
Becker radio Monza cassette stereo LW/MW/SW/USW
531 automatic antenna (с 01.01.1963)
540 roller blind, electric, for rear window (с 01.05.1985)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
580 air conditioner/Tempmatic (с 01.11.1982)
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
650 sports chassis with 15-hole light alloy rims (с 01.12.1988 по 28.02.1993)
812 rear-mounted loudspeaker (с 01.11.1974)
950 sportline (consisting of codes 65/0, 243, 281) (с 01.10.1989 по 28.02.1993)
Voisiko joku suomentaa varustelistasta kohdat 412, 551, 570, 592, 650, 950.
Ei toi Lontoo tahdo olla vahvin laji. Kiitos jo etukäteen.
Viimeksi muokannut Tu0mas, 25.5.2008 19:31. Yhteensä muokattu 2 kertaa.
toni1976
Re: Toinen mersu...
Viesti Kirjoittaja toni1976 »
Miepä yritän suomentaa :oops:
412: Sähköinen kattoluukku
551: Ajonestolaite vai onko oikeen häly :?
570: Keskikyynärnoja
592: Lämpöä hylkivät lasit :)
650: Urheilullinen alusta 15 reikäisillä aluvanteilla
950: Sportline malli
On näille varmaan jotain järkevämpiäkin nimikkeitä. Pistäkää paremmaksi :wink:
Ford Mondeo 2.0 TDCi Ghia Wagon A - 08
Saab 9-3 Sportsedan 2.0t A -05
Datsun 100A - 75
Tu0mas
Re: Toinen mersu...
toni1976 kirjoitti:Miepä yritän suomentaa :oops:
Kiitos. Nämä auttoi jo paljon. Mitähän mahtaa sportline malli sisältää?
arzka
Viesti Kirjoittaja arzka »
sportline on varustepaketti.oisko nahat,jäykempi/matalampi alusta nopeempi ohjaus ym...kivaa.näin ainakin mulla(300 farkku)
Tu0mas
Kiitos vastauksista. Nopeaa toimintaa. Pitäs vaihdella v-loppuna virranjakaja, tulpat, tulpanjohdot ja bensansuodatin. Meinaa vähän kakoa vedättäessä. Muuten auto siistissä kunnossa. Penkin puhkikuluminen ihmetyttää koska ml. on 209tkm ja huoltokirjakin löytyy. Tiedä sitten onko ruuvattu mittaria.
anttari
Viesti Kirjoittaja anttari »
Mistä jengi onkii noita numerosarjoja joista tietää värin ja kaikki varusteet?? Kantakorttiahan mulla ei oo :)
http://www.mbclub.ru/mb/vin/?lng=eng Tuonne vain runkonumero ja tulee listaa 8)
anttari
Jihuuuuu!
VIN WDB1241301A731257
Model 300 D
Chassis 1241301A731257
Engine 603912 12 026922
Transmission 722415 02 619583
Order 0 8 529 50270
Delivery date 30.05.88
Dealer Finland (529)
Interior fabric black+anthracite (071)
Paint
355 diamond blue metallic (1984-1990, с 1994)
Options
260 elimination of model designation on rear lid (с 01.05.1968)
341 additional lamp (с 01.09.1982)
483 harder springs and undershields (с 01.01.1964 по 31.07.1996)
506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
524 paintcoat preservation (с 01.01.1964)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
605 headlamp wiper unit and license plate mounting (с 01.08.1971)
oil for rear axle with limited-slip differential in canisters and trim strips on hardtop
630 ECE warning triangle (с 01.08.1980)
673 high-capacity battery (с 01.01.1964)
anttari
Tota en tajunnut??
Tu0mas
Nyt ois sitten muutama kuva otettu, tosin kännykameralla mutta kai niista jotain tolkkua saa.
http://s260.photobucket.com/albums/ii9/Tu0mas/
Mielipiteitä ja maltillisia ulkonäön parannus ehdotuksia kuulisin mielelläni!!
Nykyinen
S203 C30cdi Amg
Entiset kulkineet
W202 C36
S124 E250D
C124 300-24
C124 300
Terho P
Viesti Kirjoittaja Terho P »
aloota maalamalla maski mustaksi :lol:
avari maski edes..
no jos kahvat kopan väriin ja samalla vähä muutaki :wink:
ArPi
Lievä Eskoriihelä
Viesti Kirjoittaja ArPi »
Valojen ja vilkkujen vaihto piristää kummasti ulkonäköä.
En koskaan ota kuin yhden oluen. Sen jälkeen olen kuin toinen mies, ja se toinen mies ottaa loput...
Kaasu passatti...
ex.W202 180
ex.S204 200cdi
ex.S202 180
ex.S202 250tdt Uncle-Benz
ex.W123 250 urpodee
[miitit]0111111111111011111[/miitit]
Minun silmääni värit ovat hienot ja auto nätti tuollaisenaankin.
Jos muutosta haluaa niin ainakin kesäksi nätit vanteet koossa 16-17"
(käytettävyys / ajo-ominaisuudet jos halutaan säilyttää niin isommat eivät ole oikein hyvät)
ja kirkkaita vilkkuja + uudemman mallin takavalot.
Lasien tummennus ja Mese.fi - tarra takalasiin - siinäpä ne. 8)
Tu0mas
Muistan hämärästi, että joku olisi myynyt noita avari maskeja täällä foorumillakin?? Muistankohan väärin :roll: ?
Nykyinen
S203 C30cdi Amg
Entiset kulkineet
W202 C36
S124 E250D
C124 300-24
C124 300
Japi-Partsilta pitäisi löytyä. :roll:
Marde2
Viesti Kirjoittaja Marde2 »
Meikäläisen avarimaskista ainakin on lähtenyt suuria paloja kromausta ja se on ruostunut ja vaihtaa koko ajan väriä ruskeaksi. Melkein kannattaa hankkia vain säleikkö ilman kehystä jos vain saatavilla ja käyttää orkkis kehys. Itsekin etsimässä orkkis kehystä...
____________________________
S 320 L -99. Illaksi kotiin.
Pidä alkuperäisenä. :wink: Harvassa ovat tuunaamattomat coupet nykyisin. :roll:
romu
Orkkis-entusiasti
Viesti Kirjoittaja romu »
Wikke kirjoitti:Pidä alkuperäisenä. :wink: Harvassa ovat tuunaamattomat coupet nykyisin. :roll:
Hoen samaa. Onse komia.
Jaakko Tepon työttömän laussa on hyvä ohje:
..,että elekeepä tehkö mittään, niin ei tuu virkavirheitä. :rock:
Jarkko N
Tekninen Nero
Viesti Kirjoittaja Jarkko N »
Ajovalojen pyyhinpesuri ja rekisterikilven kiinnikkeet
Lukkoperän öljyt kanistereissa ja koristelistat (raidat) kovakattoisessa
anttari
Danke. Lukkoperän öljyt kanistereissa,onko mulla lukkoperä??
Sampo N.
Virallinen Oikolukija
Viesti Kirjoittaja Sampo N. »
Ei ainakaan listassa ollut lukkoperää :?
Kein siknatuur
Jarkko N
Tekninen Nero
Minä vain suomensin tekstit. Lukkoperämaininta koskee varmaankin vain
niitä autoja, jossa on lukkoperä, ja silti on epäselvää, mistä
kanisterista on kyse. Koodit on tulkittava mallisarjan ja ajankohdan mukaan.
En tiedä, mistä venäläiset saavat tietonsa, mutta varustekoodit
näkyvät esim. sivulla
http://www.geocities.com/MotorCity/Spee ... bcodes.htm
Siellä 605 tarkoittaa samaa kuin 600 ja 602 yhdessä eli pyyhinpesuri
valoille ja erityiset kiinnikkeet rekisterikilvelle.
Sampo N.
Jos olen oikein käsittänyt, niin lukkoperä = ASD --> Mittaristossa palaa valo talvisin melko usein ajotyylistä riippuen. Varoituskolmion pitäisi syttyä perän luistaessa sinne 120-140 alapuolelle, ei sinne missä muut varoitusvalot ovat jonossa.
Kein siknatuur
Boss
Luupiä
Viesti Kirjoittaja Boss »
Siisti vaalea karo-sisusta, ittellä oli spörtslinessa vielä erinäkönen pienemmällä kehällä orggis-nahkaruori, muuten tutunnäköistä.
Tu0mas
Noniin nyt ois halavalla amg 18" monot myynnissä, ja pääsin niitä kokeilemaankin autoni alle. Pikkusen (n.1cm) tuli korilinjan ulkopuolelle. Mitähän mahtaa katsastus-setä sanoo moisesta?
Nykyinen
S203 C30cdi Amg
Entiset kulkineet
W202 C36
S124 E250D
C124 300-24
C124 300
ArPi
Lievä Eskoriihelä
Paljon on et monoissa?
Kaasu passatti...
ex.W202 180
ex.S204 200cdi
ex.S202 180
ex.W123 250 urpodee
Tu0mas
Oiskohan ollu 35.
Nykyinen
S203 C30cdi Amg
Entiset kulkineet
W202 C36
S124 E250D
C124 300-24
C124 300
jtv000
Viesti Kirjoittaja jtv000 »
Onnittelut satalankusta, vaikka ikä tekee tehtävänsä, on ne pirun hyvin tehtyjä autoja monellakin tapaa. Itse keskittyisin tekniikan läpikäyntiin enkä tuunaukseen, mutta valinta on jokaisen oma.
ahonen v
Viesti Kirjoittaja ahonen v »
Tu0mas kirjoitti:Noniin nyt ois halavalla amg 18" monot myynnissä
Kuinka halvalla?
- mazda rx-7 -82
- lada 1600 "iS" -77
- ex. W124 260E -89
