B -huolto?
B -huolto?
Mitä kuuluu B -huoltoon, jos kyseessä C 200 CDI? Riittääkö, että vaihtaa öljyt ja suodattimet ja sitten taas menoksi?
Elikkä B on se laajempi huolto.http://www.benzworld.org kirjoitti:A- service is basically an oil service with a few checks. B service is more of the same with additional checks.
Tässä nämä FSS-huollot ameriikasta kookletettuna:
Flexible Service System - A-Service
What we do:
* Change your vehicle's engine oil and filter
* Replace the dust filter in all SLK, CLK, C-Class and E-Class models
* Ensure the warning and indicator lamps, horn, windshield/headlamp, wiper and washer systems, and seat belts are functioning correctly.
* Inspect tires and check tire pressure (including spare)
* Inspect brake pad thickness and disc condition
* Check and correct all fluid levels
* Reset your vehicle's FSS counter
*Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Flexible Service System - B-Service
What we do:
* Replace the dust filter in all SLK, CLK, C-Class and E-Class models, and in S-Class and SL-Class models without the active charcoal filter
* Replace windshield wiper inserts
* Inspect and rotate tires
* Lubricate and inspect throttle linkage
* Ensure the parking brake, steering play, headlamps and exterior lamps, warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, seat belts, and backrest lock (S-Class only) are functioning correctly
* Inspect front axle ball joints and Poly-V-belt
Pro HVM
- Lucky-Dog
- <b>Ylläpitäjä</b>
Riippuu kilometrimäärästä...esim. 6o tkm välein olisi syytä vaihtaa perä / vaihteistoöljyt....jos automattii niin sinne suodatin.
http://www.mbkoskinen.fi
